slub: remove invalid reference to list iterator variable
Author: Julia Lawall <Julia.Lawall@lip6.fr>
If list_for_each_entry, etc complete a traversal of the list, the iterator
variable ends up pointing to an address at an offset from the list head,
and not a meaningful structure.  Thus this value should not be used after
the end of the iterator.  The patch replaces s->name by al->name, which is
referenced nearby.
This problem was found using Coccinelle (http://coccinelle.lip6.fr/).
Signed-off-by: Julia Lawall
Signed-off-by: Pekka Enberg
 mm/slub.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/mm/slub.c b/mm/slub.c
index f96d8bc..79fe9c6 100644
--- a/mm/slub.c
+++ b/mm/slub.c
@@ -5405,7 +5405,7 @@ static int __init slab_sysfs_init(void)
 		err = sysfs_slab_alias(al->s, al->name);
 		if (err)
 			printk(KERN_ERR "SLUB: Unable to add boot slab alias"
-					" %s to sysfs\n", s->name);
+					" %s to sysfs\n", al->name);
 		kfree(al);
BtrLinux
Privacy Overview
