serial: vr41xx_siu: delete double assignment
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Delete successive assignments to the same location.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
expression i;
*i = ...;
 i = ...;
Signed-off-by: Julia Lawall
 drivers/tty/serial/vr41xx_siu.c | 1 -
 1 file changed, 1 deletion(-)
diff --git a/drivers/tty/serial/vr41xx_siu.c b/drivers/tty/serial/vr41xx_siu.c
index db0c8a4..d7f9d62 100644
--- a/drivers/tty/serial/vr41xx_siu.c
+++ b/drivers/tty/serial/vr41xx_siu.c
@@ -847,7 +847,6 @@ void __init vr41xx_siu_early_setup(struct uart_port *port)
 	siu_uart_ports[port->line].type = port->type;
 	siu_uart_ports[port->line].uartclk = SIU_BAUD_BASE * 16;
 	siu_uart_ports[port->line].mapbase = port->mapbase;
-	siu_uart_ports[port->line].mapbase = port->mapbase;
 	siu_uart_ports[port->line].ops = &siu_uart_ops;
BtrLinux
Privacy Overview
