serial: use time_before, time_before_eq, etc
The functions time_before, time_before_eq, time_after, and time_after_eq
are more robust for comparing jiffies against other values.
A simplified version of the semantic patch making this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@ change_compare_np @
expression E;
- jiffies <= E
+ time_before_eq(jiffies,E)
- jiffies >= E
+ time_after_eq(jiffies,E)
- jiffies < E
+ time_before(jiffies,E)
- jiffies > E
+ time_after(jiffies,E)
@ include depends on change_compare_np @
#include
@ no_include depends on !include && change_compare_np @
#include
+ #include
Signed-off-by: Julia Lawall
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
drivers/serial/68360serial.c | 3 ++-
1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/serial/68360serial.c b/drivers/serial/68360serial.c
index 2aa6bfe..f594636 100644
--- a/drivers/serial/68360serial.c
+++ b/drivers/serial/68360serial.c
@@ -51,6 +51,7 @@ extern int kgdb_output_string (const char* s, unsigned int count);
/* #ifdef CONFIG_SERIAL_CONSOLE */ /* This seems to be a post 2.0 thing - mles */
#include <linux/console.h>
+#include <linux/jiffies.h>
/* this defines the index into rs_table for the port to use
@@ -1729,7 +1730,7 @@ static void rs_360_wait_until_sent(struct tty_struct *tty, int timeout)
msleep_interruptible(jiffies_to_msecs(char_time));
if (signal_pending(current))
break;
- if (timeout && ((orig_jiffies + timeout) < jiffies))
+ if (timeout && (time_after(jiffies, orig_jiffies + timeout)))
break;
/* The 'tx_cur' is really the next buffer to send. We
* have to back up to the previous BD and wait for it |
break;
break;
