serial: icom: fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Return a negative error code on failure.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
identifier ret; expression e1,e2;
if (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Julia Lawall
 drivers/tty/serial/icom.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/tty/serial/icom.c b/drivers/tty/serial/icom.c
index d4620fe..45fc323 100644
--- a/drivers/tty/serial/icom.c
+++ b/drivers/tty/serial/icom.c
@@ -1550,8 +1550,10 @@ static int icom_probe(struct pci_dev *dev,
 	icom_adapter->base_addr = pci_ioremap_bar(dev, 0);
-	if (!icom_adapter->base_addr)
+	if (!icom_adapter->base_addr) {
+		retval = -ENOMEM;
 		goto probe_exit1;
 	 /* save off irq and request irq line */
 	 if ( (retval = request_irq(dev->irq, icom_interrupt,
BtrLinux
Privacy Overview
