[SCSI] zfcp: remove invalid reference to list iterator variable
Author: Julia Lawall <Julia.Lawall@lip6.fr>
If list_for_each_entry, etc complete a traversal of the list, the iterator
variable ends up pointing to an address at an offset from the list head,
and not a meaningful structure. Thus this value should not be used after
the end of the iterator. Replace port->adapter->scsi_host by
adapter->scsi_host.
This problem was found using Coccinelle (http://coccinelle.lip6.fr/).
Oversight in upsteam commit of v2.6.37
a1ca48319a9aa1c5b57ce142f538e76050bb8972
"[SCSI] zfcp: Move ACL/CFDC code to zfcp_cfdc.c"
which merged the content of zfcp_erp_port_access_changed().
Signed-off-by: Julia Lawall
Signed-off-by: Steffen Maier
Reviewed-by: Martin Peschke
Cc: #2.6.37+
Signed-off-by: James Bottomley
drivers/s390/scsi/zfcp_cfdc.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/s390/scsi/zfcp_cfdc.c b/drivers/s390/scsi/zfcp_cfdc.c
index fbd8b4d..49b82e4 100644
--- a/drivers/s390/scsi/zfcp_cfdc.c
+++ b/drivers/s390/scsi/zfcp_cfdc.c
@@ -293,7 +293,7 @@ void zfcp_cfdc_adapter_access_changed(struct zfcp_adapter *adapter)
read_unlock_irqrestore(&adapter->port_list_lock, flags);
- shost_for_each_device(sdev, port->adapter->scsi_host) {
+ shost_for_each_device(sdev, adapter->scsi_host) {
zfcp_sdev = sdev_to_zfcp(sdev);
status = atomic_read(&zfcp_sdev->status);
if ((status & ZFCP_STATUS_COMMON_ACCESS_DENIED) || |
