[SCSI] lpfc: Move a dereference below a NULL test
In each case, if the NULL test is necessary, then the dereference should be
moved below the NULL test.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
type T;
expression E;
identifier i,fld;
statement S;
- T i = E->fld;
+ T i;
  ... when != E
      when != i
  if (E == NULL) S
+ i = E->fld;
Signed-off-by: Julia Lawall
Acked-by: James Smart
Signed-off-by: James Bottomley
 drivers/scsi/lpfc/lpfc_init.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/scsi/lpfc/lpfc_init.c b/drivers/scsi/lpfc/lpfc_init.c
index 4c77038..6c86731 100644
--- a/drivers/scsi/lpfc/lpfc_init.c
+++ b/drivers/scsi/lpfc/lpfc_init.c
@@ -1795,12 +1795,13 @@ lpfc_block_mgmt_io(struct lpfc_hba * phba)
 int
 lpfc_online(struct lpfc_hba *phba)
-	struct lpfc_vport *vport = phba->pport;
+	struct lpfc_vport *vport;
 	struct lpfc_vport **vports;
 	int i;
 	if (!phba)
 		return 0;
+	vport = phba->pport;
 	if (!(vport->fc_flag & FC_OFFLINE_MODE))
 		return 0;
BtrLinux
Privacy Overview
