[SCSI] ipr: reorder error handling code to include iounmap
The out_msi_disable label should be before cleanup_nomem to additionally
benefit from the call to iounmap. Subsequent gotos are adjusted to go to
out_msi_disable instead of cleanup_nomem, which now follows it. This is
safe because pci_disable_msi does nothing if pci_enable_msi was not called.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
@r@
expression e1,e2;
statement S;
e1 = pci_ioremap_bar(...);
... when != e1 = e2
when != iounmap(e1)
when any
if (<+...e1...+>) S
if(...) { ... return 0; }
if (...) { ... when != iounmap(e1)
when != if (...) { ... iounmap(e1) ... }
* return ...;
} else S
Signed-off-by: Julia Lawall
Acked-by: Brian King
Signed-off-by: Andrew Morton
Signed-off-by: James Bottomley
drivers/scsi/ipr.c | 12 ++++++------
1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/drivers/scsi/ipr.c b/drivers/scsi/ipr.c
index 888086c..8d63630 100644
--- a/drivers/scsi/ipr.c
+++ b/drivers/scsi/ipr.c
@@ -8778,14 +8778,14 @@ static int __devinit ipr_probe_ioa(struct pci_dev *pdev,
if (rc != PCIBIOS_SUCCESSFUL) {
dev_err(&pdev->dev, "Failed to save PCI config space\n");
rc = -EIO;
- goto cleanup_nomem;
+ goto out_msi_disable;
if ((rc = ipr_save_pcix_cmd_reg(ioa_cfg)))
if ((rc = ipr_set_pcix_cmd_reg(ioa_cfg)))
if (ioa_cfg->sis64)
ioa_cfg->cfg_table_size = (sizeof(struct ipr_config_table_hdr64)
@@ -8800,7 +8800,7 @@ static int __devinit ipr_probe_ioa(struct pci_dev *pdev,
if (rc < 0) {
dev_err(&pdev->dev,
"Couldn't allocate enough memory for device driver!\n");
@@ -8845,10 +8845,10 @@ out:
cleanup_nolog:
ipr_free_mem(ioa_cfg);
-cleanup_nomem:
- iounmap(ipr_regs);
out_msi_disable:
pci_disable_msi(pdev);
+cleanup_nomem:
+ iounmap(ipr_regs);
out_release_regions:
pci_release_regions(pdev);
out_scsi_host_put: |
rc = -EIO;
if (ioa_cfg->sis64)
if (rc < 0) {
dev_err(&pdev->dev,
cleanup_nolog:
-cleanup_nomem:
out_msi_disable:
+cleanup_nomem:
out_scsi_host_put:
