[SCSI] fusion: Move a dereference below a NULL test
If the NULL test is necessary, then the dereference should be moved below
the NULL test.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/).
@disable is_null@
identifier f;
expression E;
identifier fld;
statement S;
+ if (E == NULL) S
  f(...,E->fld,...);
- if (E == NULL) S
identifier f;
expression E;
identifier fld;
statement S;
+ if (!E) S
  f(...,E->fld,...);
- if (!E) S
Signed-off-by: Julia Lawall
Acked-by: "Prakash, Sathya"
Signed-off-by: James Bottomley
 drivers/message/fusion/mptctl.c | 5 +++--
 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/drivers/message/fusion/mptctl.c b/drivers/message/fusion/mptctl.c
index b89f476..c638171 100644
--- a/drivers/message/fusion/mptctl.c
+++ b/drivers/message/fusion/mptctl.c
@@ -308,10 +308,11 @@ static void mptctl_timeout_expired (MPT_IOCTL *ioctl)
 	int rc = 1;
-	dctlprintk(ioctl->ioc, printk(MYIOC_s_DEBUG_FMT ": Timeout Expired! Host %d\n",
-				ioctl->ioc->name, ioctl->ioc->id));
 	if (ioctl == NULL)
 		return;
+	dctlprintk(ioctl->ioc,
+		   printk(MYIOC_s_DEBUG_FMT ": Timeout Expired! Host %d\n",
+		   ioctl->ioc->name, ioctl->ioc->id));
 	ioctl->wait_done = 0;
 	if (ioctl->reset & MPTCTL_RESET_OK)
BtrLinux
Privacy Overview
