[SCSI] drivers/scsi: Adjust confusing if indentation
Outdent the code following the if.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@r disable braces4@
position p1,p2;
statement S1,S2;
if (...) { ... }
if (...) S1@p1 S2@p2
@script:python@
p1 << r.p1;
p2 << r.p2;
if (p1[0].column == p2[0].column):
  cocci.print_main("branch",p1)
  cocci.print_secs("after",p2)
Signed-off-by: Julia Lawall
Acked-by: Nick Cheng
Signed-off-by: James Bottomley
 drivers/scsi/arcmsr/arcmsr_hba.c    | 4 ++--
 drivers/scsi/mpt2sas/mpt2sas_base.c | 2 +-
 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/scsi/arcmsr/arcmsr_hba.c b/drivers/scsi/arcmsr/arcmsr_hba.c
index c8dc392..05a78e5 100644
--- a/drivers/scsi/arcmsr/arcmsr_hba.c
+++ b/drivers/scsi/arcmsr/arcmsr_hba.c
@@ -878,8 +878,8 @@ static void arcmsr_report_ccb_state(struct AdapterControlBlock *acb,
 	if (!error) {
 		if (acb->devstate[id][lun] == ARECA_RAID_GONE)
 			acb->devstate[id][lun] = ARECA_RAID_GOOD;
-			ccb->pcmd->result = DID_OK << 16;
-			arcmsr_ccb_complete(ccb);
+		ccb->pcmd->result = DID_OK << 16;
+		arcmsr_ccb_complete(ccb);
 	}else{
 		switch (ccb->arcmsr_cdb.DeviceStatus) {
 		case ARCMSR_DEV_SELECT_TIMEOUT: {
diff --git a/drivers/scsi/mpt2sas/mpt2sas_base.c b/drivers/scsi/mpt2sas/mpt2sas_base.c
index 57bcd5c..12faf64 100644
--- a/drivers/scsi/mpt2sas/mpt2sas_base.c
+++ b/drivers/scsi/mpt2sas/mpt2sas_base.c
@@ -534,7 +534,7 @@ _base_display_event_data(struct MPT2SAS_ADAPTER *ioc,
 		if (event_data->DiscoveryStatus)
 			printk("discovery_status(0x%08x)",
 			    le32_to_cpu(event_data->DiscoveryStatus));
-			printk("\n");
+		printk("\n");
 		return;
 	case MPI2_EVENT_SAS_BROADCAST_PRIMITIVE:
BtrLinux
Privacy Overview
