sched, sysctl: Delete an unnecessary check before unregister_sysctl_table()
Author: Markus Elfring <elfring@users.sourceforge.net>
The unregister_sysctl_table() function tests whether its argument is NULL
and then returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Peter Zijlstra (Intel)
Cc: Linus Torvalds
Cc: Mike Galbraith
Cc: Peter Zijlstra
Cc: Thomas Gleixner
Link: http://lkml.kernel.org/r/5597877E.3060503@users.sourceforge.net
Signed-off-by: Ingo Molnar
kernel/sched/core.c | 3 +--
1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/kernel/sched/core.c b/kernel/sched/core.c
index 78b4bad10..48be7dc 100644
--- a/kernel/sched/core.c
+++ b/kernel/sched/core.c
@@ -5311,8 +5311,7 @@ static void register_sched_domain_sysctl(void)
/* may be called multiple times per register */
static void unregister_sched_domain_sysctl(void)
- if (sd_sysctl_header)
- unregister_sysctl_table(sd_sysctl_header);
+ unregister_sysctl_table(sd_sysctl_header);
sd_sysctl_header = NULL;
if (sd_ctl_dir[0].child)
sd_free_ctl_entry(&sd_ctl_dir[0].child); |
