sata_mv: Delete unnecessary checks before the function call “phy_power_off”
Author: Markus Elfring <elfring@users.sourceforge.net>
The phy_power_off() function tests whether its argument is NULL and then
returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Tejun Heo
 drivers/ata/sata_mv.c | 6 ++----
 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/drivers/ata/sata_mv.c b/drivers/ata/sata_mv.c
index f9a0e34..f8c33e3 100644
--- a/drivers/ata/sata_mv.c
+++ b/drivers/ata/sata_mv.c
@@ -4185,8 +4185,7 @@ err:
 			clk_disable_unprepare(hpriv->port_clks[port]);
 			clk_put(hpriv->port_clks[port]);
-		if (hpriv->port_phys[port])
-			phy_power_off(hpriv->port_phys[port]);
+		phy_power_off(hpriv->port_phys[port]);
 	return rc;
@@ -4216,8 +4215,7 @@ static int mv_platform_remove(struct platform_device *pdev)
 	return 0;
BtrLinux
Privacy Overview
