s390/pci: Deletion of unnecessary checks before the function call “debug_unregister”
Author: Markus Elfring <elfring@users.sourceforge.net>
The debug_unregister() function performs also input parameter validation.
Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Sebastian Ott
Signed-off-by: Martin Schwidefsky
 arch/s390/pci/pci_debug.c | 7 ++-----
 1 file changed, 2 insertions(+), 5 deletions(-)
diff --git a/arch/s390/pci/pci_debug.c b/arch/s390/pci/pci_debug.c
index eec598c..3229a2e 100644
--- a/arch/s390/pci/pci_debug.c
+++ b/arch/s390/pci/pci_debug.c
@@ -158,10 +158,7 @@ int __init zpci_debug_init(void)
 void zpci_debug_exit(void)
-	if (pci_debug_msg_id)
-		debug_unregister(pci_debug_msg_id);
-	if (pci_debug_err_id)
-		debug_unregister(pci_debug_err_id);
+	debug_unregister(pci_debug_msg_id);
+	debug_unregister(pci_debug_err_id);
 	debugfs_remove(debugfs_root);
BtrLinux
Privacy Overview
