s390/pci: Delete an unnecessary check before the function call “pci_dev_put”
Author: Markus Elfring <elfring@users.sourceforge.net>
The pci_dev_put() function tests whether its argument is NULL and then
returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Martin Schwidefsky
 arch/s390/pci/pci_event.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/arch/s390/pci/pci_event.c b/arch/s390/pci/pci_event.c
index fb2a9a5..c2b27ad 100644
--- a/arch/s390/pci/pci_event.c
+++ b/arch/s390/pci/pci_event.c
@@ -145,8 +145,7 @@ static void __zpci_event_availability(struct zpci_ccdf_avail *ccdf)
 	default:
 		break;
-	if (pdev)
-		pci_dev_put(pdev);
+	pci_dev_put(pdev);
 void zpci_event_availability(void *data)
BtrLinux
Privacy Overview
