s390/oprofile: make return of 0 explicit
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Delete unnecessary local variable whose value is always 0 and that hides
the fact that the result is always 0.
A simplified version of the semantic patch that fixes this problem is as
follows: (http://coccinelle.lip6.fr/)
@r exists@
local idexpression ret;
expression e;
position p;
-ret = 0;
... when != ret = e
return
- ret
+ 0
[heiko.carstens: turn prepare_cpu_buffers into a void returning function]
Signed-off-by: Julia Lawall
Signed-off-by: Heiko Carstens
Signed-off-by: Martin Schwidefsky
 arch/s390/oprofile/hwsampler.c | 14 ++++----------
 1 file changed, 4 insertions(+), 10 deletions(-)
diff --git a/arch/s390/oprofile/hwsampler.c b/arch/s390/oprofile/hwsampler.c
index 276f2e2..e53c6f2 100644
--- a/arch/s390/oprofile/hwsampler.c
+++ b/arch/s390/oprofile/hwsampler.c
@@ -209,13 +209,11 @@ static void init_all_cpu_buffers(void)
-static int prepare_cpu_buffers(void)
+static void prepare_cpu_buffers(void)
-	int cpu;
-	int rc;
 	struct hws_cpu_buffer *cb;
+	int cpu;
-	rc = 0;
 	for_each_online_cpu(cpu) {
 		cb = &per_cpu(sampler_cpu_buffer, cpu);
 		atomic_set(&cb->ext_params, 0);
@@ -230,8 +228,6 @@ static int prepare_cpu_buffers(void)
 		cb->oom = 0;
 		cb->stop_mode = 0;
-	return rc;
@@ -1107,9 +1103,7 @@ int hwsampler_start_all(unsigned long rate)
 	if (rc)
 		goto start_all_exit;
-	rc = prepare_cpu_buffers();
-	if (rc)
-		goto start_all_exit;
+	prepare_cpu_buffers();
 		rc = start_sampling(cpu);
@@ -1156,7 +1150,7 @@ int hwsampler_stop_all(void)
 	rc = 0;
 	if (hws_state == HWS_INIT) {
 		mutex_unlock(&hws_sem);
-		return rc;
+		return 0;
 	hws_state = HWS_STOPPING;
BtrLinux
Privacy Overview
