s390/net: Delete useless checks before function calls
Author: Markus Elfring <elfring@users.sourceforge.net>
The function debug_unregister() tests whether its argument is
NULL and then returns immediately. Thus the test around the call
is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Ursula Braun
Signed-off-by: David S. Miller
drivers/s390/net/claw.c | 6 ++----
drivers/s390/net/lcs.c | 6 ++----
drivers/s390/net/netiucv.c | 9 +++------
3 files changed, 7 insertions(+), 14 deletions(-)
diff --git a/drivers/s390/net/claw.c b/drivers/s390/net/claw.c
index 213e54e..d609ca0 100644
--- a/drivers/s390/net/claw.c
+++ b/drivers/s390/net/claw.c
@@ -109,10 +109,8 @@ static debug_info_t *claw_dbf_trace;
static void
claw_unregister_debug_facility(void)
- if (claw_dbf_setup)
- debug_unregister(claw_dbf_setup);
- if (claw_dbf_trace)
- debug_unregister(claw_dbf_trace);
+ debug_unregister(claw_dbf_setup);
+ debug_unregister(claw_dbf_trace);
static int
diff --git a/drivers/s390/net/lcs.c b/drivers/s390/net/lcs.c
index 92190aa..00b7d9c 100644
--- a/drivers/s390/net/lcs.c
+++ b/drivers/s390/net/lcs.c
@@ -88,10 +88,8 @@ static debug_info_t *lcs_dbf_trace;
static void
lcs_unregister_debug_facility(void)
- if (lcs_dbf_setup)
- debug_unregister(lcs_dbf_setup);
- if (lcs_dbf_trace)
- debug_unregister(lcs_dbf_trace);
+ debug_unregister(lcs_dbf_setup);
+ debug_unregister(lcs_dbf_trace);
static int
diff --git a/drivers/s390/net/netiucv.c b/drivers/s390/net/netiucv.c
index 7e91f54..33f7040 100644
--- a/drivers/s390/net/netiucv.c
+++ b/drivers/s390/net/netiucv.c
@@ -487,12 +487,9 @@ DEFINE_PER_CPU(char[256], iucv_dbf_txt_buf);
static void iucv_unregister_dbf_views(void)
- if (iucv_dbf_setup)
- debug_unregister(iucv_dbf_setup);
- if (iucv_dbf_data)
- debug_unregister(iucv_dbf_data);
- if (iucv_dbf_trace)
- debug_unregister(iucv_dbf_trace);
+ debug_unregister(iucv_dbf_setup);
+ debug_unregister(iucv_dbf_data);
+ debug_unregister(iucv_dbf_trace);
static int iucv_register_dbf_views(void)
static void
static int
static void
static int
