s390/cio: add NULL test
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Add NULL test on call to kzalloc.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
expression x;
identifier fld;
* x = kzalloc(...);
  ... when != x == NULL
  x->fld
Signed-off-by: Julia Lawall
Signed-off-by: Heiko Carstens
Signed-off-by: Martin Schwidefsky
 drivers/s390/char/con3215.c | 2 ++
 1 file changed, 2 insertions(+)
diff --git a/drivers/s390/char/con3215.c b/drivers/s390/char/con3215.c
index 0fc3fe5..7d82bbc 100644
--- a/drivers/s390/char/con3215.c
+++ b/drivers/s390/char/con3215.c
@@ -922,6 +922,8 @@ static int __init con3215_init(void)
 	spin_lock_init(&raw3215_freelist_lock);
 	for (i = 0; i < NR_3215_REQ; i++) {
 		req = kzalloc(sizeof(struct raw3215_req), GFP_KERNEL | GFP_DMA);
+		if (!req)
+			return -ENOMEM;
 		req->next = raw3215_freelist;
 		raw3215_freelist = req;
