[S390] s390: Remove redundant test
The loop above the modified code only terminates when rc is a valid pointer.
A simplified version of the semantic patch that makes this change is as
follows: (http://www.emn.fr/x-info/coccinelle/)
@r exists@
local idexpression x;
expression E;
position p1,p2;
if (x@p1 == NULL || ...) { ... when forall
   return ...; }
... when != \(x=E\|x--\|x++\|--x\|++x\|x-=E\|x+=E\|x|=E\|x&=E\|&x\)
x@p2 == NULL
x@p2 != NULL
// another path to the test that is not through p1?
@s exists@
local idexpression r.x;
position r.p1,r.p2;
... when != x@p1
x@p2 == NULL
x@p2 != NULL
@fix depends on !s@
position r.p1,r.p2;
expression x,E;
statement S1,S2;
- if ((x@p2 != NULL) || ...)
  S1
- if ((x@p2 == NULL) && ...) S1
- BUG_ON(x@p2 == NULL);
Signed-off-by: Julia Lawall
Signed-off-by: Martin Schwidefsky
 arch/s390/kernel/debug.c          | 2 +-
 drivers/s390/net/qeth_core_main.c | 1 -
 2 files changed, 1 insertion(+), 2 deletions(-)
diff --git a/arch/s390/kernel/debug.c b/arch/s390/kernel/debug.c
index d80fcd4..21c9037 100644
--- a/arch/s390/kernel/debug.c
+++ b/arch/s390/kernel/debug.c
@@ -388,7 +388,7 @@ debug_info_copy(debug_info_t* in, int mode)
 		debug_info_free(rc);
 	} while (1);
-        if(!rc || (mode == NO_AREAS))
+	if (mode == NO_AREAS)
                 goto out;
         for(i = 0; i < in->nr_areas; i++){
diff --git a/drivers/s390/net/qeth_core_main.c b/drivers/s390/net/qeth_core_main.c
index 3dc752c..bacd58c 100644
--- a/drivers/s390/net/qeth_core_main.c
+++ b/drivers/s390/net/qeth_core_main.c
@@ -2335,7 +2335,6 @@ static int qeth_init_input_buffer(struct qeth_card *card,
 	 * the QETH_IN_BUF_REQUEUE_THRESHOLD we should never run  out off
 	 * buffers
-	BUG_ON(!pool_entry);
 	buf->pool_entry = pool_entry;
 	for (i = 0; i < QETH_MAX_BUFFER_ELEMENTS(card); ++i) {
BtrLinux
Privacy Overview
