s390: Delete unnecessary checks before the function call “debug_unregister”
Author: Markus Elfring <elfring@users.sourceforge.net>
The debug_unregister() function performs also input parameter validation.
Thus the test around the calls is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Heiko Carstens
Signed-off-by: Martin Schwidefsky
 drivers/s390/cio/chsc_sch.c      | 3 +--
 drivers/s390/cio/cio.c           | 9 +++------
 drivers/s390/cio/qdio_debug.c    | 6 ++----
 drivers/s390/crypto/zcrypt_api.c | 6 ++----
 4 files changed, 8 insertions(+), 16 deletions(-)
diff --git a/drivers/s390/cio/chsc_sch.c b/drivers/s390/cio/chsc_sch.c
index 213159d..378c571 100644
--- a/drivers/s390/cio/chsc_sch.c
+++ b/drivers/s390/cio/chsc_sch.c
@@ -185,8 +185,7 @@ static int __init chsc_init_dbfs(void)
 	debug_set_level(chsc_debug_log_id, 2);
 	return 0;
 out:
-	if (chsc_debug_msg_id)
-		debug_unregister(chsc_debug_msg_id);
+	debug_unregister(chsc_debug_msg_id);
 	return -ENOMEM;
diff --git a/drivers/s390/cio/cio.c b/drivers/s390/cio/cio.c
index e0d0295..2d18205 100644
--- a/drivers/s390/cio/cio.c
+++ b/drivers/s390/cio/cio.c
@@ -76,12 +76,9 @@ static int __init cio_debug_init(void)
 	return 0;
 out_unregister:
-	if (cio_debug_msg_id)
-		debug_unregister(cio_debug_msg_id);
-	if (cio_debug_trace_id)
-		debug_unregister(cio_debug_trace_id);
-	if (cio_debug_crw_id)
-		debug_unregister(cio_debug_crw_id);
+	debug_unregister(cio_debug_msg_id);
+	debug_unregister(cio_debug_trace_id);
+	debug_unregister(cio_debug_crw_id);
 	return -1;
diff --git a/drivers/s390/cio/qdio_debug.c b/drivers/s390/cio/qdio_debug.c
index f1f3baa..b6fc147 100644
--- a/drivers/s390/cio/qdio_debug.c
+++ b/drivers/s390/cio/qdio_debug.c
@@ -366,8 +366,6 @@ void qdio_debug_exit(void)
 	qdio_clear_dbf_list();
 	debugfs_remove(debugfs_root);
-	if (qdio_dbf_setup)
-		debug_unregister(qdio_dbf_setup);
-	if (qdio_dbf_error)
-		debug_unregister(qdio_dbf_error);
+	debug_unregister(qdio_dbf_setup);
+	debug_unregister(qdio_dbf_error);
diff --git a/drivers/s390/crypto/zcrypt_api.c b/drivers/s390/crypto/zcrypt_api.c
index 9f8fa42..5d3d04c 100644
--- a/drivers/s390/crypto/zcrypt_api.c
+++ b/drivers/s390/crypto/zcrypt_api.c
@@ -1428,10 +1428,8 @@ int __init zcrypt_debug_init(void)
 void zcrypt_debug_exit(void)
-	if (zcrypt_dbf_common)
-		debug_unregister(zcrypt_dbf_common);
-	if (zcrypt_dbf_devices)
-		debug_unregister(zcrypt_dbf_devices);
+	debug_unregister(zcrypt_dbf_common);
+	debug_unregister(zcrypt_dbf_devices);
BtrLinux
Privacy Overview
