s390-ctcm: Delete unnecessary checks before the function call “channel_remove”
Author: Markus Elfring <elfring@users.sourceforge.net>
The channel_remove() function tests whether its argument is NULL
and then returns immediately. Thus the test around the calls is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Ursula Braun
Signed-off-by: David S. Miller
 drivers/s390/net/ctcm_main.c | 7 ++-----
 1 file changed, 2 insertions(+), 5 deletions(-)
diff --git a/drivers/s390/net/ctcm_main.c b/drivers/s390/net/ctcm_main.c
index 05c37d6..c3e2252 100644
--- a/drivers/s390/net/ctcm_main.c
+++ b/drivers/s390/net/ctcm_main.c
@@ -1677,11 +1677,8 @@ static int ctcm_shutdown_device(struct ccwgroup_device *cgdev)
 	ccw_device_set_offline(cgdev->cdev[1]);
 	ccw_device_set_offline(cgdev->cdev[0]);
-	if (priv->channel[CTCM_READ])
-		channel_remove(priv->channel[CTCM_READ]);
-	if (priv->channel[CTCM_WRITE])
-		channel_remove(priv->channel[CTCM_WRITE]);
+	channel_remove(priv->channel[CTCM_READ]);
+	channel_remove(priv->channel[CTCM_WRITE]);
 	priv->channel[CTCM_READ] = priv->channel[CTCM_WRITE] = NULL;
 	return 0;
BtrLinux
Privacy Overview
