rxrpc: fix ptr_ret.cocci warnings
Author: Wu Fengguang <fengguang.wu@intel.com>
net/rxrpc/rxkad.c:1165:1-3: WARNING: PTR_ERR_OR_ZERO can be used
 Use PTR_ERR_OR_ZERO rather than if(IS_ERR(...)) + PTR_ERR
Generated by: scripts/coccinelle/api/ptr_ret.cocci
CC: David Howells
Signed-off-by: Fengguang Wu
Signed-off-by: David S. Miller
 net/rxrpc/rxkad.c | 4 +---
 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/net/rxrpc/rxkad.c b/net/rxrpc/rxkad.c
index 6b726a0..bab56ed 100644
--- a/net/rxrpc/rxkad.c
+++ b/net/rxrpc/rxkad.c
@@ -1162,9 +1162,7 @@ static int rxkad_init(void)
 	/* pin the cipher we need so that the crypto layer doesn't invoke
 	 * keventd to go get it */
 	rxkad_ci = crypto_alloc_skcipher("pcbc(fcrypt)", 0, CRYPTO_ALG_ASYNC);
-	if (IS_ERR(rxkad_ci))
-		return PTR_ERR(rxkad_ci);
-	return 0;
+	return PTR_ERR_OR_ZERO(rxkad_ci);
BtrLinux
Privacy Overview
