rtlwifi: rtl818x: constify rtl_intf_ops structures
Author: Julia Lawall <Julia.Lawall@lip6.fr>
The rtl_intf_ops structures are never modified, so declare them as const.
Done with the help of Coccinelle.
Signed-off-by: Julia Lawall
Signed-off-by: Kalle Valo
 drivers/net/wireless/realtek/rtlwifi/pci.c  | 2 +-
 drivers/net/wireless/realtek/rtlwifi/pci.h  | 2 +-
 drivers/net/wireless/realtek/rtlwifi/usb.c  | 2 +-
 drivers/net/wireless/realtek/rtlwifi/wifi.h | 2 +-
 4 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/net/wireless/realtek/rtlwifi/pci.c b/drivers/net/wireless/realtek/rtlwifi/pci.c
index 1ac41b8..66030ea 100644
--- a/drivers/net/wireless/realtek/rtlwifi/pci.c
+++ b/drivers/net/wireless/realtek/rtlwifi/pci.c
@@ -2456,7 +2456,7 @@ int rtl_pci_resume(struct device *dev)
 EXPORT_SYMBOL(rtl_pci_resume);
 #endif /* CONFIG_PM_SLEEP */
-struct rtl_intf_ops rtl_pci_ops = {
+const struct rtl_intf_ops rtl_pci_ops = {
 	.read_efuse_byte = read_efuse_byte,
 	.adapter_start = rtl_pci_start,
 	.adapter_stop = rtl_pci_stop,
diff --git a/drivers/net/wireless/realtek/rtlwifi/pci.h b/drivers/net/wireless/realtek/rtlwifi/pci.h
index 5da6703..b951eba 100644
--- a/drivers/net/wireless/realtek/rtlwifi/pci.h
+++ b/drivers/net/wireless/realtek/rtlwifi/pci.h
@@ -286,7 +286,7 @@ struct rtl_pci_priv {
 int rtl_pci_reset_trx_ring(struct ieee80211_hw *hw);
-extern struct rtl_intf_ops rtl_pci_ops;
+extern const struct rtl_intf_ops rtl_pci_ops;
 int rtl_pci_probe(struct pci_dev *pdev,
 			    const struct pci_device_id *id);
diff --git a/drivers/net/wireless/realtek/rtlwifi/usb.c b/drivers/net/wireless/realtek/rtlwifi/usb.c
index aac1ed3..41617b7 100644
--- a/drivers/net/wireless/realtek/rtlwifi/usb.c
+++ b/drivers/net/wireless/realtek/rtlwifi/usb.c
@@ -1049,7 +1049,7 @@ static void rtl_fill_h2c_cmd_work_callback(struct work_struct *work)
 	rtlpriv->cfg->ops->fill_h2c_cmd(hw, H2C_RA_MASK, 5, rtlpriv->rate_mask);
-static struct rtl_intf_ops rtl_usb_ops = {
+static const struct rtl_intf_ops rtl_usb_ops = {
 	.adapter_start = rtl_usb_start,
 	.adapter_stop = rtl_usb_stop,
 	.adapter_tx = rtl_usb_tx,
diff --git a/drivers/net/wireless/realtek/rtlwifi/wifi.h b/drivers/net/wireless/realtek/rtlwifi/wifi.h
index 11d9c23..4e0ab4d 100644
--- a/drivers/net/wireless/realtek/rtlwifi/wifi.h
+++ b/drivers/net/wireless/realtek/rtlwifi/wifi.h
@@ -2593,7 +2593,7 @@ struct rtl_priv {
 	 *intf_ops : for diff interrface usb/pcie
 	struct rtl_hal_cfg *cfg;
-	struct rtl_intf_ops *intf_ops;
+	const struct rtl_intf_ops *intf_ops;
 	/*this var will be set by set_bit,
 	   and was used to indicate status of
BtrLinux
Privacy Overview
