rtc: use c99 initializers in structures
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Use c99 initializers for structures.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
@decl@
identifier i1,fld;
type T;
field list[n] fs;
struct i1 {
fs
T fld;
@bad@
identifier decl.i1,i2;
expression e;
initializer list[decl.n] is;
struct i1 i2 = { is,
+ .fld = e
- e
Signed-off-by: Julia Lawall
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
drivers/rtc/rtc-pcf8583.c | 18 +++++++++++++++---
1 file changed, 15 insertions(+), 3 deletions(-)
diff --git a/drivers/rtc/rtc-pcf8583.c b/drivers/rtc/rtc-pcf8583.c
index c263984..5911a6d 100644
--- a/drivers/rtc/rtc-pcf8583.c
+++ b/drivers/rtc/rtc-pcf8583.c
@@ -176,7 +176,11 @@ static int pcf8583_rtc_read_time(struct device *dev, struct rtc_time *tm)
struct i2c_client *client = to_i2c_client(dev);
unsigned char ctrl, year[2];
- struct rtc_mem mem = { CMOS_YEAR, sizeof(year), year };
+ struct rtc_mem mem = {
+ .loc = CMOS_YEAR,
+ .nr = sizeof(year),
+ .data = year
int real_year, year_offset, err;
@@ -222,8 +226,16 @@ static int pcf8583_rtc_set_time(struct device *dev, struct rtc_time *tm)
unsigned char year[2], chk;
- struct rtc_mem cmos_year = { CMOS_YEAR, sizeof(year), year };
- struct rtc_mem cmos_check = { CMOS_CHECKSUM, 1, &chk };
+ struct rtc_mem cmos_year = {
+ .loc = CMOS_YEAR,
+ .data = year
+ struct rtc_mem cmos_check = {
+ .loc = CMOS_CHECKSUM,
+ .nr = 1,
+ .data = &chk
unsigned int proper_year = tm->tm_year + 1900;
int ret; |
+ .loc = CMOS_YEAR,
+ .data = year
+ .loc = CMOS_YEAR,
+ .data = year
+ .nr = 1,
+ .data = &chk
int ret;
