rtc: simplify devm_request_mem_region/devm_ioremap
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Convert the composition of devm_request_mem_region and devm_ioremap to a
single call to devm_ioremap_resource.  The associated call to
platform_get_resource is also simplified and moved next to the new call
This was done using a combination of the semantic patches
devm_ioremap_resource.cocci and devm_request_and_ioremap.cocci, found in
the scripts/coccinelle/api directory.
In rtc-lpc32xx.c and rtc-mv.c, the local variable size is no longer needed.
In rtc-ds1511.c the size field of the local structure is not useful any
more, and is deleted.
Signed-off-by: Julia Lawall
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 drivers/rtc/rtc-ds1511.c   | 17 +++++------------
 drivers/rtc/rtc-ds1553.c   | 13 ++++---------
 drivers/rtc/rtc-ep93xx.c   | 14 +++-----------
 drivers/rtc/rtc-imxdi.c    | 16 ++++------------
 drivers/rtc/rtc-lpc32xx.c  | 24 ++++--------------------
 drivers/rtc/rtc-mv.c       | 17 ++++-------------
 drivers/rtc/rtc-mxc.c      | 14 ++++----------
 drivers/rtc/rtc-stk17ta8.c | 15 +++++----------
 drivers/rtc/rtc-tx4939.c   | 14 ++++----------
 9 files changed, 37 insertions(+), 107 deletions(-)
diff --git a/drivers/rtc/rtc-ds1511.c b/drivers/rtc/rtc-ds1511.c
index 308a8fe..bc7b4fc 100644
--- a/drivers/rtc/rtc-ds1511.c
+++ b/drivers/rtc/rtc-ds1511.c
@@ -89,7 +89,6 @@ enum ds1511reg {
 struct rtc_plat_data {
 	struct rtc_device *rtc;
 	void __iomem *ioaddr;		/* virtual base address */
-	int size;				/* amount of memory mapped */
 	int irq;
 	unsigned int irqen;
 	int alrm_sec;
@@ -479,20 +478,14 @@ static int ds1511_rtc_probe(struct platform_device *pdev)
 	struct rtc_plat_data *pdata;
 	int ret = 0;
-	res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
-	if (!res)
-		return -ENODEV;
 	pdata = devm_kzalloc(&pdev->dev, sizeof(*pdata), GFP_KERNEL);
 	if (!pdata)
 		return -ENOMEM;
-	pdata->size = resource_size(res);
-	if (!devm_request_mem_region(&pdev->dev, res->start, pdata->size,
-			pdev->name))
-		return -EBUSY;
-	ds1511_base = devm_ioremap(&pdev->dev, res->start, pdata->size);
-	if (!ds1511_base)
-		return -ENOMEM;
+	res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
+	ds1511_base = devm_ioremap_resource(&pdev->dev, res);
+	if (IS_ERR(ds1511_base))
+		return PTR_ERR(ds1511_base);
 	pdata->ioaddr = ds1511_base;
 	pdata->irq = platform_get_irq(pdev, 0);
diff --git a/drivers/rtc/rtc-ds1553.c b/drivers/rtc/rtc-ds1553.c
index 8c6c952..fd31571 100644
--- a/drivers/rtc/rtc-ds1553.c
+++ b/drivers/rtc/rtc-ds1553.c
@@ -285,19 +285,14 @@ static int ds1553_rtc_probe(struct platform_device *pdev)
 	int ret = 0;
-	if (!res)
-		return -ENODEV;
 	if (!pdata)
 		return -ENOMEM;
-	if (!devm_request_mem_region(&pdev->dev, res->start, RTC_REG_SIZE,
-			pdev->name))
-		return -EBUSY;
-	ioaddr = devm_ioremap(&pdev->dev, res->start, RTC_REG_SIZE);
-	if (!ioaddr)
-		return -ENOMEM;
+	ioaddr = devm_ioremap_resource(&pdev->dev, res);
+	if (IS_ERR(ioaddr))
+		return PTR_ERR(ioaddr);
 	pdata->ioaddr = ioaddr;
diff --git a/drivers/rtc/rtc-ep93xx.c b/drivers/rtc/rtc-ep93xx.c
index 549b3c3..580e7b5 100644
--- a/drivers/rtc/rtc-ep93xx.c
+++ b/drivers/rtc/rtc-ep93xx.c
@@ -138,17 +138,9 @@ static int ep93xx_rtc_probe(struct platform_device *pdev)
 		return -ENOMEM;
-	if (!res)
-		return -ENXIO;
-				     resource_size(res), pdev->name))
-		return -EBUSY;
-	ep93xx_rtc->mmio_base = devm_ioremap(&pdev->dev, res->start,
-					     resource_size(res));
-	if (!ep93xx_rtc->mmio_base)
-		return -ENXIO;
+	ep93xx_rtc->mmio_base = devm_ioremap_resource(&pdev->dev, res);
+	if (IS_ERR(ep93xx_rtc->mmio_base))
+		return PTR_ERR(ep93xx_rtc->mmio_base);
 	pdev->dev.platform_data = ep93xx_rtc;
 	platform_set_drvdata(pdev, ep93xx_rtc);
diff --git a/drivers/rtc/rtc-imxdi.c b/drivers/rtc/rtc-imxdi.c
index d3a8c8e..abd7f90 100644
--- a/drivers/rtc/rtc-imxdi.c
+++ b/drivers/rtc/rtc-imxdi.c
@@ -375,24 +375,16 @@ static int __init dryice_rtc_probe(struct platform_device *pdev)
 	struct imxdi_dev *imxdi;
 	int rc;
-	if (!res)
-		return -ENODEV;
 	imxdi = devm_kzalloc(&pdev->dev, sizeof(*imxdi), GFP_KERNEL);
 	if (!imxdi)
 		return -ENOMEM;
 	imxdi->pdev = pdev;
-	if (!devm_request_mem_region(&pdev->dev, res->start, resource_size(res),
-				pdev->name))
-		return -EBUSY;
-	imxdi->ioaddr = devm_ioremap(&pdev->dev, res->start,
-	if (imxdi->ioaddr == NULL)
-		return -ENOMEM;
+	imxdi->ioaddr = devm_ioremap_resource(&pdev->dev, res);
+	if (IS_ERR(imxdi->ioaddr))
+		return PTR_ERR(imxdi->ioaddr);
 	spin_lock_init(&imxdi->irq_lock);
diff --git a/drivers/rtc/rtc-lpc32xx.c b/drivers/rtc/rtc-lpc32xx.c
index 8276ae9..bfdbcb8 100644
--- a/drivers/rtc/rtc-lpc32xx.c
+++ b/drivers/rtc/rtc-lpc32xx.c
@@ -201,16 +201,9 @@ static int lpc32xx_rtc_probe(struct platform_device *pdev)
 	struct resource *res;
 	struct lpc32xx_rtc *rtc;
-	resource_size_t size;
 	int rtcirq;
 	u32 tmp;
-	if (!res) {
-		dev_err(&pdev->dev, "Can't get memory resource\n");
-		return -ENOENT;
 	rtcirq = platform_get_irq(pdev, 0);
 	if (rtcirq < 0 || rtcirq >= NR_IRQS) {
 		dev_warn(&pdev->dev, "Can't get interrupt resource\n");
@@ -224,19 +217,10 @@ static int lpc32xx_rtc_probe(struct platform_device *pdev)
 	rtc->irq = rtcirq;
-	size = resource_size(res);
-	if (!devm_request_mem_region(&pdev->dev, res->start, size,
-				     pdev->name)) {
-		dev_err(&pdev->dev, "RTC registers are not free\n");
-		return -EBUSY;
-	rtc->rtc_base = devm_ioremap(&pdev->dev, res->start, size);
-	if (!rtc->rtc_base) {
-		dev_err(&pdev->dev, "Can't map memory\n");
-		return -ENOMEM;
+	rtc->rtc_base = devm_ioremap_resource(&pdev->dev, res);
+	if (IS_ERR(rtc->rtc_base))
+		return PTR_ERR(rtc->rtc_base);
 	spin_lock_init(&rtc->lock);
diff --git a/drivers/rtc/rtc-mv.c b/drivers/rtc/rtc-mv.c
index baab802..d536c59 100644
--- a/drivers/rtc/rtc-mv.c
+++ b/drivers/rtc/rtc-mv.c
@@ -221,26 +221,17 @@ static int __init mv_rtc_probe(struct platform_device *pdev)
 	u32 rtc_time;
 	int ret = 0;
-	if (!res)
-		return -ENODEV;
 	if (!pdata)
 		return -ENOMEM;
-				     pdev->name))
-		return -EBUSY;
-	pdata->ioaddr = devm_ioremap(&pdev->dev, res->start, size);
-	if (!pdata->ioaddr)
-		return -ENOMEM;
+	pdata->ioaddr = devm_ioremap_resource(&pdev->dev, res);
+	if (IS_ERR(pdata->ioaddr))
+		return PTR_ERR(pdata->ioaddr);
 	pdata->clk = devm_clk_get(&pdev->dev, NULL);
 	/* Not all SoCs require a clock.*/
diff --git a/drivers/rtc/rtc-mxc.c b/drivers/rtc/rtc-mxc.c
index ab87bac..50c5726 100644
--- a/drivers/rtc/rtc-mxc.c
+++ b/drivers/rtc/rtc-mxc.c
@@ -377,22 +377,16 @@ static int mxc_rtc_probe(struct platform_device *pdev)
 	unsigned long rate;
 	int ret;
-	if (!res)
-		return -ENODEV;
 	if (!pdata)
 		return -ENOMEM;
 	pdata->devtype = pdev->id_entry->driver_data;
-		return -EBUSY;
 	if (IS_ERR(pdata->clk)) {
diff --git a/drivers/rtc/rtc-stk17ta8.c b/drivers/rtc/rtc-stk17ta8.c
index af5e97e..a176ba6 100644
--- a/drivers/rtc/rtc-stk17ta8.c
+++ b/drivers/rtc/rtc-stk17ta8.c
@@ -294,19 +294,14 @@ static int stk17ta8_rtc_probe(struct platform_device *pdev)
 	int ret = 0;
-	if (!res)
-		return -ENODEV;
 	if (!pdata)
 		return -ENOMEM;
-			pdev->name))
-		return -EBUSY;
-	if (!ioaddr)
-		return -ENOMEM;
diff --git a/drivers/rtc/rtc-tx4939.c b/drivers/rtc/rtc-tx4939.c
index f9a0677..4f87234 100644
--- a/drivers/rtc/rtc-tx4939.c
+++ b/drivers/rtc/rtc-tx4939.c
@@ -244,9 +244,6 @@ static int __init tx4939_rtc_probe(struct platform_device *pdev)
 	int irq, ret;
-	if (!res)
-		return -ENODEV;
 	if (irq < 0)
 		return -ENODEV;
@@ -255,13 +252,10 @@ static int __init tx4939_rtc_probe(struct platform_device *pdev)
 		return -ENOMEM;
 	platform_set_drvdata(pdev, pdata);
-		return -EBUSY;
-	pdata->rtcreg = devm_ioremap(&pdev->dev, res->start,
-	if (!pdata->rtcreg)
-		return -EBUSY;
+	pdata->rtcreg = devm_ioremap_resource(&pdev->dev, res);
+	if (IS_ERR(pdata->rtcreg))
+		return PTR_ERR(pdata->rtcreg);
 	spin_lock_init(&pdata->lock);
 	tx4939_rtc_cmd(pdata->rtcreg, TX4939_RTCCTL_COMMAND_NOP);
