rtc: rv8803: fix handling return value of i2c_smbus_read_byte_data
Author: Andrzej Hajda <a.hajda@samsung.com>
The function can return negative values, so its result should
be assigned to signed variable.
The problem has been detected using proposed semantic patch
scripts/coccinelle/tests/assign_signed_to_unsigned.cocci [1].
[1]: http://permalink.gmane.org/gmane.linux.kernel/2046107
Signed-off-by: Andrzej Hajda
Signed-off-by: Alexandre Belloni
 drivers/rtc/rtc-rv8803.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/rtc/rtc-rv8803.c b/drivers/rtc/rtc-rv8803.c
index e7329e2..f883aa2 100644
--- a/drivers/rtc/rtc-rv8803.c
+++ b/drivers/rtc/rtc-rv8803.c
@@ -61,7 +61,7 @@ static irqreturn_t rv8803_handle_irq(int irq, void *dev_id)
 	struct i2c_client *client = dev_id;
 	struct rv8803_data *rv8803 = i2c_get_clientdata(client);
 	unsigned long events = 0;
-	u8 flags;
+	int flags;
 	spin_lock(&rv8803->flags_lock);
BtrLinux
Privacy Overview
