rtc: ds1685: Use module_platform_driver
Author: Vaishali Thakkar <vthakkar1994@gmail.com>
Use module_platform_driver for drivers whose init and exit functions
only register and unregister, respectively.
A simplified version of the Coccinelle semantic patch that performs
this transformation is as follows:
@a@
identifier f, x;
-static f(...) { return platform_driver_register(&x); }
@b depends on a@
identifier e, a.x;
-static e(...) { platform_driver_unregister(&x); }
@c depends on a && b@
identifier a.f;
declarer name module_init;
-module_init(f);
@d depends on a && b && c@
identifier b.e, a.x;
declarer name module_exit;
declarer name module_platform_driver;
-module_exit(e);
+module_platform_driver(x);
Signed-off-by: Vaishali Thakkar
Signed-off-by: Alexandre Belloni
 drivers/rtc/rtc-ds1685.c | 22 +---------------------
 1 file changed, 1 insertion(+), 21 deletions(-)
diff --git a/drivers/rtc/rtc-ds1685.c b/drivers/rtc/rtc-ds1685.c
index 818a363..05a51ef 100644
--- a/drivers/rtc/rtc-ds1685.c
+++ b/drivers/rtc/rtc-ds1685.c
@@ -2145,27 +2145,7 @@ static struct platform_driver ds1685_rtc_driver = {
 	.probe		= ds1685_rtc_probe,
 	.remove		= ds1685_rtc_remove,
- * ds1685_rtc_init - rtc module init.
-static int __init
-ds1685_rtc_init(void)
-	return platform_driver_register(&ds1685_rtc_driver);
- * ds1685_rtc_exit - rtc module exit.
-static void __exit
-ds1685_rtc_exit(void)
-	platform_driver_unregister(&ds1685_rtc_driver);
-module_init(ds1685_rtc_init);
-module_exit(ds1685_rtc_exit);
+module_platform_driver(ds1685_rtc_driver);
BtrLinux
Privacy Overview
