rtc-at91sam9: Correct size given to memset
Memset should be given the size of the structure, not the size of the
pointer.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
type T;
T *x;
expression E;
memset(x, E, sizeof(
 x))
Signed-off-by: Julia Lawall
Signed-off-by: Alessandro Zummo
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 drivers/rtc/rtc-at91sam9.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/rtc/rtc-at91sam9.c b/drivers/rtc/rtc-at91sam9.c
index 86c61f1..78a018b 100644
--- a/drivers/rtc/rtc-at91sam9.c
+++ b/drivers/rtc/rtc-at91sam9.c
@@ -161,7 +161,7 @@ static int at91_rtc_readalarm(struct device *dev, struct rtc_wkalrm *alrm)
 	if (offset == 0)
 		return -EILSEQ;
-	memset(alrm, 0, sizeof(alrm));
+	memset(alrm, 0, sizeof(*alrm));
 	if (alarm != ALARM_DISABLED && offset != 0) {
 		rtc_time_to_tm(offset + alarm, tm);
BtrLinux
Privacy Overview
