rtc: asm9260: remove .owner field for driver
Author: Wei Yongjun <weiyj.lk@gmail.com>
Remove .owner field if calls are used which set it automatically.
Generated by: scripts/coccinelle/api/platform_no_drv_owner.cocci
Signed-off-by: Wei Yongjun
Signed-off-by: Alexandre Belloni
 drivers/rtc/rtc-asm9260.c | 1 -
 1 file changed, 1 deletion(-)
diff --git a/drivers/rtc/rtc-asm9260.c b/drivers/rtc/rtc-asm9260.c
index 355fdb9..5219916 100644
--- a/drivers/rtc/rtc-asm9260.c
+++ b/drivers/rtc/rtc-asm9260.c
@@ -343,7 +343,6 @@ static struct platform_driver asm9260_rtc_driver = {
 	.remove		= asm9260_rtc_remove,
 	.driver		= {
 		.name	= "asm9260-rtc",
-		.owner	= THIS_MODULE,
 		.of_match_table = asm9260_dt_ids,
BtrLinux
Privacy Overview
