regulator: wm831x: Pass the IRQF_ONESHOT flag
Author: Fabio Estevam <fabio.estevam@freescale.com>
Since commit 1c6c69525b40 ("genirq: Reject bogus threaded irq requests")
threaded IRQs without a primary handler need to be requested with
IRQF_ONESHOT, otherwise the request will fail.
So pass the IRQF_ONESHOT flag in this case.
The semantic patch that makes this change is available
in scripts/coccinelle/misc/irqf_oneshot.cocci.
Signed-off-by: Fabio Estevam
Signed-off-by: Mark Brown
 drivers/regulator/wm831x-dcdc.c  | 12 ++++++++----
 drivers/regulator/wm831x-isink.c |  3 ++-
 drivers/regulator/wm831x-ldo.c   |  6 ++++--
 3 files changed, 14 insertions(+), 7 deletions(-)
diff --git a/drivers/regulator/wm831x-dcdc.c b/drivers/regulator/wm831x-dcdc.c
index 0d7e164..8cbb82c 100644
--- a/drivers/regulator/wm831x-dcdc.c
+++ b/drivers/regulator/wm831x-dcdc.c
@@ -533,7 +533,8 @@ static int wm831x_buckv_probe(struct platform_device *pdev)
 	irq = wm831x_irq(wm831x, platform_get_irq_byname(pdev, "UV"));
 	ret = devm_request_threaded_irq(&pdev->dev, irq, NULL,
 					wm831x_dcdc_uv_irq,
-					IRQF_TRIGGER_RISING, dcdc->name, dcdc);
+					IRQF_TRIGGER_RISING | IRQF_ONESHOT,
+					dcdc->name, dcdc);
 	if (ret != 0) {
 		dev_err(&pdev->dev, "Failed to request UV IRQ %d: %d\n",
 			irq, ret);
@@ -543,7 +544,8 @@ static int wm831x_buckv_probe(struct platform_device *pdev)
 	irq = wm831x_irq(wm831x, platform_get_irq_byname(pdev, "HC"));
 					wm831x_dcdc_oc_irq,
 	if (ret != 0) {
 		dev_err(&pdev->dev, "Failed to request HC IRQ %d: %d\n",
 			irq, ret);
@@ -669,7 +671,8 @@ static int wm831x_buckp_probe(struct platform_device *pdev)
 					wm831x_dcdc_uv_irq,
 	if (ret != 0) {
 			irq, ret);
@@ -785,7 +788,8 @@ static int wm831x_boostp_probe(struct platform_device *pdev)
 					wm831x_dcdc_uv_irq,
+					dcdc->name,
 					dcdc);
 	if (ret != 0) {
diff --git a/drivers/regulator/wm831x-isink.c b/drivers/regulator/wm831x-isink.c
index 1e88391..1442828 100644
--- a/drivers/regulator/wm831x-isink.c
+++ b/drivers/regulator/wm831x-isink.c
@@ -204,7 +204,8 @@ static int wm831x_isink_probe(struct platform_device *pdev)
 	irq = wm831x_irq(wm831x, platform_get_irq(pdev, 0));
 					wm831x_isink_irq,
-					IRQF_TRIGGER_RISING, isink->name,
+					isink->name,
 					isink);
 	if (ret != 0) {
 		dev_err(&pdev->dev, "Failed to request ISINK IRQ %d: %d\n",
diff --git a/drivers/regulator/wm831x-ldo.c b/drivers/regulator/wm831x-ldo.c
index 7ae2dc8..5a7b65e 100644
--- a/drivers/regulator/wm831x-ldo.c
+++ b/drivers/regulator/wm831x-ldo.c
@@ -287,7 +287,8 @@ static int wm831x_gp_ldo_probe(struct platform_device *pdev)
 					wm831x_ldo_uv_irq,
-					IRQF_TRIGGER_RISING, ldo->name,
+					ldo->name,
 					ldo);
 	if (ret != 0) {
@@ -496,7 +497,8 @@ static int wm831x_aldo_probe(struct platform_device *pdev)
 					wm831x_ldo_uv_irq,
-					IRQF_TRIGGER_RISING, ldo->name, ldo);
+					ldo->name, ldo);
 	if (ret != 0) {
 			irq, ret);
BtrLinux
Privacy Overview
