regulator: ti-abb: simplify platform_get_resource_byname/devm_ioremap_resource
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Remove unneeded error handling on the result of a call to
platform_get_resource_byname when the value is passed to devm_ioremap_resource.
A simplified version of the semantic patch that makes this change is as
follows: (http://coccinelle.lip6.fr/)
expression pdev,res,e,e1;
expression ret != 0;
identifier l;
res = platform_get_resource_byname(...);
- if (res == NULL) { ... \(goto l;\|return ret;\) }
e = devm_ioremap_resource(e1, res);
Signed-off-by: Julia Lawall
Signed-off-by: Mark Brown
drivers/regulator/ti-abb-regulator.c | 10 ----------
1 file changed, 10 deletions(-)
diff --git a/drivers/regulator/ti-abb-regulator.c b/drivers/regulator/ti-abb-regulator.c
index 3753ed0..d8e3e12 100644
--- a/drivers/regulator/ti-abb-regulator.c
+++ b/drivers/regulator/ti-abb-regulator.c
@@ -717,11 +717,6 @@ static int ti_abb_probe(struct platform_device *pdev)
/* Map ABB resources */
pname = "base-address";
res = platform_get_resource_byname(pdev, IORESOURCE_MEM, pname);
- if (!res) {
- dev_err(dev, "Missing '%s' IO resource\n", pname);
- ret = -ENODEV;
- goto err;
abb->base = devm_ioremap_resource(dev, res);
if (IS_ERR(abb->base)) {
ret = PTR_ERR(abb->base);
@@ -770,11 +765,6 @@ static int ti_abb_probe(struct platform_device *pdev)
pname = "ldo-address";
- if (!res) {
- dev_dbg(dev, "Missing '%s' IO resource\n", pname);
- ret = -ENODEV;
- goto skip_opt;
abb->ldo_base = devm_ioremap_resource(dev, res);
if (IS_ERR(abb->ldo_base)) {
ret = PTR_ERR(abb->ldo_base); |
- if (!res) {
- ret = -ENODEV;
- goto err;
- if (!res) {
- ret = -ENODEV;
- goto skip_opt;
