regulator: s5m8767: adjust duplicate test
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Delete successive tests to the same location.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
@s exists@
local idexpression y;
expression x,e;
*if ( \(x == NULL\|IS_ERR(x)\|y != 0\) )
 { ... when forall
   return ...; }
... when != \(y = e\|y += e\|y -= e\|y |= e\|y &= e\|y++\|y--\|&y\)
 { ... when forall
   return ...; }
Signed-off-by: Julia Lawall
Signed-off-by: Mark Brown
 drivers/regulator/s5m8767.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/regulator/s5m8767.c b/drivers/regulator/s5m8767.c
index 8a83194..8e56198 100644
--- a/drivers/regulator/s5m8767.c
+++ b/drivers/regulator/s5m8767.c
@@ -549,7 +549,7 @@ static int s5m8767_pmic_dt_parse_pdata(struct platform_device *pdev,
 	rmode = devm_kzalloc(&pdev->dev, sizeof(*rmode) *
 				pdata->num_regulators, GFP_KERNEL);
-	if (!rdata) {
+	if (!rmode) {
 		dev_err(iodev->dev,
 			"could not allocate memory for regulator mode\n");
 		return -ENOMEM;
BtrLinux
Privacy Overview
