regulator: lp8788: constify regulator_ops structures
Author: Julia Lawall <Julia.Lawall@lip6.fr>
The regulator_ops structures are never modified, so declare them as const.
Done with the help of Coccinelle.
Signed-off-by: Julia Lawall
Acked-by: Milo Kim
Signed-off-by: Mark Brown
 drivers/regulator/lp8788-buck.c | 4 ++--
 drivers/regulator/lp8788-ldo.c  | 4 ++--
 2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/regulator/lp8788-buck.c b/drivers/regulator/lp8788-buck.c
index a97bed9..ec46290 100644
--- a/drivers/regulator/lp8788-buck.c
+++ b/drivers/regulator/lp8788-buck.c
@@ -344,7 +344,7 @@ static unsigned int lp8788_buck_get_mode(struct regulator_dev *rdev)
 				REGULATOR_MODE_FAST : REGULATOR_MODE_NORMAL;
-static struct regulator_ops lp8788_buck12_ops = {
+static const struct regulator_ops lp8788_buck12_ops = {
 	.list_voltage = regulator_list_voltage_table,
 	.map_voltage = regulator_map_voltage_ascend,
 	.set_voltage_sel = lp8788_buck12_set_voltage_sel,
@@ -357,7 +357,7 @@ static struct regulator_ops lp8788_buck12_ops = {
 	.get_mode = lp8788_buck_get_mode,
-static struct regulator_ops lp8788_buck34_ops = {
+static const struct regulator_ops lp8788_buck34_ops = {
 	.set_voltage_sel = regulator_set_voltage_sel_regmap,
diff --git a/drivers/regulator/lp8788-ldo.c b/drivers/regulator/lp8788-ldo.c
index 30e28b1..cbfd358 100644
--- a/drivers/regulator/lp8788-ldo.c
+++ b/drivers/regulator/lp8788-ldo.c
@@ -170,7 +170,7 @@ static int lp8788_ldo_enable_time(struct regulator_dev *rdev)
 	return ENABLE_TIME_USEC * val;
-static struct regulator_ops lp8788_ldo_voltage_table_ops = {
+static const struct regulator_ops lp8788_ldo_voltage_table_ops = {
 	.get_voltage_sel = regulator_get_voltage_sel_regmap,
@@ -180,7 +180,7 @@ static struct regulator_ops lp8788_ldo_voltage_table_ops = {
 	.enable_time = lp8788_ldo_enable_time,
-static struct regulator_ops lp8788_ldo_voltage_fixed_ops = {
+static const struct regulator_ops lp8788_ldo_voltage_fixed_ops = {
 	.list_voltage = regulator_list_voltage_linear,
 	.enable = regulator_enable_regmap,
 	.disable = regulator_disable_regmap,
BtrLinux
Privacy Overview
