regulator: fix simple_return.cocci warnings
Author: Julia Lawall <julia.lawall@lip6.fr>
Simplify a trivial if-return sequence and combine with a
preceding function call.
Generated by: scripts/coccinelle/misc/simple_return.cocci
CC: Mark Brown
Signed-off-by: Julia Lawall
Signed-off-by: Mark Brown
drivers/regulator/qcom_spmi-regulator.c | 6 +-----
1 file changed, 1 insertion(+), 5 deletions(-)
diff --git a/drivers/regulator/qcom_spmi-regulator.c b/drivers/regulator/qcom_spmi-regulator.c
index 162b865..15bba2b 100644
--- a/drivers/regulator/qcom_spmi-regulator.c
+++ b/drivers/regulator/qcom_spmi-regulator.c
@@ -710,12 +710,8 @@ static int spmi_regulator_ult_lo_smps_set_voltage(struct regulator_dev *rdev,
if (range_sel == 1)
voltage_sel |= ULT_SMPS_RANGE_SPLIT;
- ret = spmi_vreg_update_bits(vreg, SPMI_COMMON_REG_VOLTAGE_SET,
+ return spmi_vreg_update_bits(vreg, SPMI_COMMON_REG_VOLTAGE_SET,
voltage_sel, 0xff);
- if (ret)
- return ret;
- return 0;
static int spmi_regulator_ult_lo_smps_get_voltage(struct regulator_dev *rdev) |
if (range_sel == 1)
voltage_sel, 0xff);
- if (ret)
- return ret;
- return 0;
