regulator: fan53555: Use PTR_RET function
Author: Alexandru Gheorghiu <gheorghiuandru@gmail.com>
Used PTR_RET function instead of IS_ERR and PTR_ERR.
Patch found using coccinelle.
Signed-off-by: Alexandru Gheorghiu
Signed-off-by: Mark Brown
 drivers/regulator/fan53555.c | 4 +---
 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/regulator/fan53555.c b/drivers/regulator/fan53555.c
index 9165b0c..f0e1ae5 100644
--- a/drivers/regulator/fan53555.c
+++ b/drivers/regulator/fan53555.c
@@ -219,9 +219,7 @@ static int fan53555_regulator_register(struct fan53555_device_info *di,
 	rdesc->owner = THIS_MODULE;
 	di->rdev = regulator_register(&di->desc, config);
-	if (IS_ERR(di->rdev))
-		return PTR_ERR(di->rdev);
-	return 0;
+	return PTR_RET(di->rdev);
BtrLinux
Privacy Overview
