regulator: act8865: Fix missing of_node_put() in act8865_pdata_from_dt()
Author: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
This node pointer is returned by of_get_child_by_name() with
refcount incremented in this function. of_node_put() is missing
when exitting this function while invalid device type. Fix it
by move of_get_child_by_name() code after device type check.
Found by Coccinelle.
Signed-off-by: Wei Yongjun
Signed-off-by: Mark Brown
 drivers/regulator/act8865-regulator.c | 12 ++++++------
 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/drivers/regulator/act8865-regulator.c b/drivers/regulator/act8865-regulator.c
index a1cd0d4..7652477 100644
--- a/drivers/regulator/act8865-regulator.c
+++ b/drivers/regulator/act8865-regulator.c
@@ -395,12 +395,6 @@ static int act8865_pdata_from_dt(struct device *dev,
 	struct act8865_regulator_data *regulator;
 	struct of_regulator_match *matches;
-	np = of_get_child_by_name(dev->of_node, "regulators");
-	if (!np) {
-		dev_err(dev, "missing 'regulators' subnode in DT\n");
-		return -EINVAL;
 	switch (type) {
 	case ACT8600:
 		matches = act8600_matches;
@@ -419,6 +413,12 @@ static int act8865_pdata_from_dt(struct device *dev,
 		return -EINVAL;
+	np = of_get_child_by_name(dev->of_node, "regulators");
+	if (!np) {
+		dev_err(dev, "missing 'regulators' subnode in DT\n");
+		return -EINVAL;
 	matched = of_regulator_match(dev, np, matches, num_matches);
 	of_node_put(np);
 	if (matched <= 0)
BtrLinux
Privacy Overview
