regmap-irq: set IRQF_ONESHOT flag to ensure IRQ request
Author: Valentin Rothberg <Valentin.Rothberg@lip6.fr>
Since commit 1c6c69525b40eb76de8adf039409722015927dc3 ("genirq: Reject
bogus threaded irq requests") threaded IRQs without a primary handler
need to be requested with IRQF_ONESHOT, otherwise the request will fail.
The %irq_flags flag is used to request the threaded IRQ and is also a
parameter of the caller.  Hence, we cannot be sure that IRQF_ONESHOT is
set.  This change avoids the potentially missing flag by setting
IRQF_ONESHOT when requesting the threaded IRQ.
Generated by: scripts/coccinelle/misc/irqf_oneshot.cocci
Signed-off-by: Valentin Rothberg
Signed-off-by: Mark Brown
 drivers/base/regmap/regmap-irq.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/base/regmap/regmap-irq.c b/drivers/base/regmap/regmap-irq.c
index 6299a50..a6c3f75 100644
--- a/drivers/base/regmap/regmap-irq.c
+++ b/drivers/base/regmap/regmap-irq.c
@@ -499,7 +499,8 @@ int regmap_add_irq_chip(struct regmap *map, int irq, int irq_flags,
 		goto err_alloc;
-	ret = request_threaded_irq(irq, NULL, regmap_irq_thread, irq_flags,
+	ret = request_threaded_irq(irq, NULL, regmap_irq_thread,
+				   irq_flags | IRQF_ONESHOT,
 				   chip->name, d);
 	if (ret != 0) {
 		dev_err(map->dev, "Failed to request IRQ %d for %s: %d\n",
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
