regmap: fix coccinelle warnings
Author: Nenghua Cao <nhcao@marvell.com>
   /drivers/base/regmap/regmap.c:717:6-33: WARNING:
Comparison to bool.
   More information about semantic patching is available at
http://coccinelle.lip6.fr/
Signed-off-by: Nenghua Cao
Signed-off-by: Mark Brown
 drivers/base/regmap/regmap.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/base/regmap/regmap.c b/drivers/base/regmap/regmap.c
index 9a426c0..92d9b79 100644
--- a/drivers/base/regmap/regmap.c
+++ b/drivers/base/regmap/regmap.c
@@ -718,7 +718,7 @@ skip_format_initialization:
 		new->window_start = range_cfg->window_start;
 		new->window_len = range_cfg->window_len;
-		if (_regmap_range_add(map, new) == false) {
+		if (!_regmap_range_add(map, new)) {
 			dev_err(map->dev, "Failed to add range %d\n", i);
 			kfree(new);
 			goto err_range;
BtrLinux
Privacy Overview
