regmap: drop unneeded goto
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Delete jump to a label on the next line, when that label is not
used elsewhere.
A simplified version of the semantic patch that makes this change is as
follows: (http://coccinelle.lip6.fr/)
@r@
identifier l;
-if (...) goto l;
-l:
Signed-off-by: Julia Lawall
Signed-off-by: Mark Brown
drivers/base/regmap/regmap.c | 3 ---
1 file changed, 3 deletions(-)
diff --git a/drivers/base/regmap/regmap.c b/drivers/base/regmap/regmap.c
index 6273ff0..ed36bb3 100644
--- a/drivers/base/regmap/regmap.c
+++ b/drivers/base/regmap/regmap.c
@@ -2583,10 +2583,7 @@ int regmap_register_patch(struct regmap *map, const struct reg_default *regs,
map->async = true;
ret = _regmap_multi_reg_write(map, regs, num_regs);
- if (ret != 0)
- goto out;
-out:
map->async = false;
map->cache_bypass = bypass; |
map->async = true;
- if (ret != 0)
- goto out;
-out:
map->async = false;
