RDMA/nes: constify nes_cm_ops structure
Author: Julia Lawall <Julia.Lawall@lip6.fr>
The nes_cm_ops structure is never modified, so declare it as const.
Done with the help of Coccinelle.
Signed-off-by: Julia Lawall
Signed-off-by: Doug Ledford
drivers/infiniband/hw/nes/nes_cm.c | 2 +-
drivers/infiniband/hw/nes/nes_cm.h | 2 +-
2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/infiniband/hw/nes/nes_cm.c b/drivers/infiniband/hw/nes/nes_cm.c
index bc37adb..179490d 100644
--- a/drivers/infiniband/hw/nes/nes_cm.c
+++ b/drivers/infiniband/hw/nes/nes_cm.c
@@ -134,7 +134,7 @@ static void record_ird_ord(struct nes_cm_node *, u16, u16);
/* External CM API Interface */
/* instance of function pointers for client API */
/* set address of this instance to cm_core->cm_ops at cm_core alloc */
-static struct nes_cm_ops nes_cm_api = {
+static const struct nes_cm_ops nes_cm_api = {
mini_cm_accelerated,
mini_cm_listen,
mini_cm_del_listen,
diff --git a/drivers/infiniband/hw/nes/nes_cm.h b/drivers/infiniband/hw/nes/nes_cm.h
index 32a6420..147c2c8 100644
--- a/drivers/infiniband/hw/nes/nes_cm.h
+++ b/drivers/infiniband/hw/nes/nes_cm.h
@@ -423,7 +423,7 @@ struct nes_cm_core {
struct timer_list tcp_timer;
- struct nes_cm_ops *api;
+ const struct nes_cm_ops *api;
int (*post_event)(struct nes_cm_event *event);
atomic_t events_posted; |
mini_cm_listen,
mini_cm_del_listen,
