RDMA/cxgb4: Move dereference below NULL test
Author: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
spatch with a semantic match is used to found this.
(http://coccinelle.lip6.fr/)
Signed-off-by: Wei Yongjun
Acked-by: Steve Wise
Signed-off-by: Roland Dreier
 drivers/infiniband/hw/cxgb4/cm.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/infiniband/hw/cxgb4/cm.c b/drivers/infiniband/hw/cxgb4/cm.c
index 51f4206..6cfd4d8 100644
--- a/drivers/infiniband/hw/cxgb4/cm.c
+++ b/drivers/infiniband/hw/cxgb4/cm.c
@@ -1361,11 +1361,11 @@ static int abort_rpl(struct c4iw_dev *dev, struct sk_buff *skb)
 	struct tid_info *t = dev->rdev.lldi.tids;
 	ep = lookup_tid(t, tid);
-	PDBG("%s ep %p tid %u\n", __func__, ep, ep->hwtid);
 	if (!ep) {
 		printk(KERN_WARNING MOD "Abort rpl to freed endpoint\n");
 		return 0;
+	PDBG("%s ep %p tid %u\n", __func__, ep, ep->hwtid);
 	mutex_lock(&ep->com.mutex);
 	switch (ep->com.state) {
 	case ABORTING:
BtrLinux
Privacy Overview
