RDMA/cxgb3: use WARN
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Use WARN rather than printk followed by WARN_ON(1), for conciseness.
A simplified version of the semantic patch that makes this transformation
is as follows: (http://coccinelle.lip6.fr/)
expression list es;
-printk(
+WARN(1,
  es);
-WARN_ON(1);
Signed-off-by: Julia Lawall
Acked-by: Steve Wise
Signed-off-by: Roland Dreier
 drivers/infiniband/hw/cxgb3/iwch_cm.c | 6 ++----
 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/drivers/infiniband/hw/cxgb3/iwch_cm.c b/drivers/infiniband/hw/cxgb3/iwch_cm.c
index aaf88ef9..3e094cd 100644
--- a/drivers/infiniband/hw/cxgb3/iwch_cm.c
+++ b/drivers/infiniband/hw/cxgb3/iwch_cm.c
@@ -128,9 +128,8 @@ static void stop_ep_timer(struct iwch_ep *ep)
 	PDBG("%s ep %p\n", __func__, ep);
 	if (!timer_pending(&ep->timer)) {
-		printk(KERN_ERR "%s timer stopped when its not running!  ep %p state %u\n",
+		WARN(1, "%s timer stopped when its not running!  ep %p state %u\n",
 			__func__, ep, ep->com.state);
-		WARN_ON(1);
 		return;
 	del_timer_sync(&ep->timer);
@@ -1756,9 +1755,8 @@ static void ep_timeout(unsigned long arg)
 		__state_set(&ep->com, ABORTING);
 		break;
 	default:
-		printk(KERN_ERR "%s unexpected state ep %p state %u\n",
+		WARN(1, "%s unexpected state ep %p state %u\n",
-		WARN_ON(1);
 		abort = 0;
 	spin_unlock_irqrestore(&ep->com.lock, flags);
BtrLinux
Privacy Overview
