RDMA/cxgb3: Use AF_INET for sin_family field
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
Elsewhere the sin_family field holds a value with a name of the form
AF_..., so it seems reasonable to do so here as well.  Also the values
of PF_INET and AF_INET are the same.
The Coccinelle semantic patch that makes this change is as follows:
struct sockaddr_in sip;
sip.sin_family ==
- PF_INET
+ AF_INET
sip.sin_family !=
- PF_INET
+ AF_INET
sip.sin_family =
- PF_INET
+ AF_INET
Signed-off-by: Amitoj Kaur Chawla
Signed-off-by: Doug Ledford
 drivers/infiniband/hw/cxgb3/iwch_cm.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/infiniband/hw/cxgb3/iwch_cm.c b/drivers/infiniband/hw/cxgb3/iwch_cm.c
index 3e8431b..04bbf17 100644
--- a/drivers/infiniband/hw/cxgb3/iwch_cm.c
+++ b/drivers/infiniband/hw/cxgb3/iwch_cm.c
@@ -1396,10 +1396,10 @@ static int pass_accept_req(struct t3cdev *tdev, struct sk_buff *skb, void *ctx)
 	state_set(&child_ep->com, CONNECTING);
 	child_ep->com.tdev = tdev;
 	child_ep->com.cm_id = NULL;
-	child_ep->com.local_addr.sin_family = PF_INET;
+	child_ep->com.local_addr.sin_family = AF_INET;
 	child_ep->com.local_addr.sin_port = req->local_port;
 	child_ep->com.local_addr.sin_addr.s_addr = req->local_ip;
-	child_ep->com.remote_addr.sin_family = PF_INET;
+	child_ep->com.remote_addr.sin_family = AF_INET;
 	child_ep->com.remote_addr.sin_port = req->peer_port;
 	child_ep->com.remote_addr.sin_addr.s_addr = req->peer_ip;
 	get_ep(&parent_ep->com);
BtrLinux
Privacy Overview
