rcu: Protect uses of ->jiffies_stall with ACCESS_ONCE()
Author: Himangi Saraogi <himangi774@gmail.com>
Some of the accesses to the rcu_state structure's ->jiffies_stall
field are unprotected. This patch protects them with ACCESS_ONCE().
The following coccinelle script was used to acheive this:
/* coccinelle script to protect uses of ->jiffies_stall with ACCESS_ONCE() */
identifier a;
	ACCESS_ONCE(a->jiffies_stall)
-	a->jiffies_stall
+	ACCESS_ONCE(a->jiffies_stall)
Signed-off-by: Himangi Saraogi
Signed-off-by: Paul E. McKenney
Reviewed-by: Josh Triplett
 kernel/rcu/tiny_plugin.h | 8 ++++----
 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/kernel/rcu/tiny_plugin.h b/kernel/rcu/tiny_plugin.h
index 4315285..858c565 100644
--- a/kernel/rcu/tiny_plugin.h
+++ b/kernel/rcu/tiny_plugin.h
@@ -144,7 +144,7 @@ static void check_cpu_stall(struct rcu_ctrlblk *rcp)
 		return;
 	rcp->ticks_this_gp++;
 	j = jiffies;
-	js = rcp->jiffies_stall;
+	js = ACCESS_ONCE(rcp->jiffies_stall);
 	if (*rcp->curtail && ULONG_CMP_GE(j, js)) {
 		pr_err("INFO: %s stall on CPU (%lu ticks this GP) idle=%llx (t=%lu jiffies q=%ld)\n",
 		       rcp->name, rcp->ticks_this_gp, rcu_dynticks_nesting,
@@ -152,17 +152,17 @@ static void check_cpu_stall(struct rcu_ctrlblk *rcp)
 		dump_stack();
-		rcp->jiffies_stall = jiffies +
+		ACCESS_ONCE(rcp->jiffies_stall) = jiffies +
 			3 * rcu_jiffies_till_stall_check() + 3;
 	else if (ULONG_CMP_GE(j, js))
-		rcp->jiffies_stall = jiffies + rcu_jiffies_till_stall_check();
+		ACCESS_ONCE(rcp->jiffies_stall) = jiffies + rcu_jiffies_till_stall_check();
 static void reset_cpu_stall_ticks(struct rcu_ctrlblk *rcp)
 	rcp->ticks_this_gp = 0;
 	rcp->gp_start = jiffies;
 static void check_cpu_stalls(void)
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
