rbd: use rbd_segment_name_free() instead of kfree()
Author: Himangi Saraogi <himangi774@gmail.com>
Free memory allocated using kmem_cache_zalloc using kmem_cache_free
rather than kfree. The helper rbd_segment_name_free does the job here.
Its position is shifted above the calling function.
The Coccinelle semantic patch that detects this change is as follows:
expression x,E,c;
x = \(kmem_cache_alloc\|kmem_cache_zalloc\|kmem_cache_alloc_node\)(c,...)
... when != x = E
when != &x
?-kfree(x)
+kmem_cache_free(c,x)
Signed-off-by: Himangi Saraogi
Acked-by: Julia Lawall
Signed-off-by: Ilya Dryomov
drivers/block/rbd.c | 16 ++++++++--------
1 file changed, 8 insertions(+), 8 deletions(-)
diff --git a/drivers/block/rbd.c b/drivers/block/rbd.c
index adedb39..703b728 100644
--- a/drivers/block/rbd.c
+++ b/drivers/block/rbd.c
@@ -1139,6 +1139,13 @@ static void rbd_dev_mapping_clear(struct rbd_device *rbd_dev)
rbd_dev->mapping.features = 0;
+static void rbd_segment_name_free(const char *name)
+ /* The explicit cast here is needed to drop the const qualifier */
+ kmem_cache_free(rbd_segment_name_cache, (void *)name);
static const char *rbd_segment_name(struct rbd_device *rbd_dev, u64 offset)
char *name;
@@ -1158,20 +1165,13 @@ static const char *rbd_segment_name(struct rbd_device *rbd_dev, u64 offset)
if (ret < 0 || ret > CEPH_MAX_OID_NAME_LEN) {
pr_err("error formatting segment name for #%llu (%d)\n",
segment, ret);
- kfree(name);
+ rbd_segment_name_free(name);
name = NULL;
return name;
-static void rbd_segment_name_free(const char *name)
- /* The explicit cast here is needed to drop the const qualifier */
- kmem_cache_free(rbd_segment_name_cache, (void *)name);
static u64 rbd_segment_offset(struct rbd_device *rbd_dev, u64 offset)
u64 segment_size = (u64) 1 << rbd_dev->header.obj_order; |
char *name;
segment, ret);
- kfree(name);
name = NULL;
return name;
