r8152: Use kmemdup instead of kmalloc + memcpy
Author: Benoit Taine <benoit.taine@lip6.fr>
This issue was reported by coccicheck using the semantic patch
at scripts/coccinelle/api/memdup.cocci
Signed-off-by: Benoit Taine
Signed-off-by: David S. Miller
 drivers/net/usb/r8152.c | 4 +---
 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/net/usb/r8152.c b/drivers/net/usb/r8152.c
index 9f91c7a..2543196 100644
--- a/drivers/net/usb/r8152.c
+++ b/drivers/net/usb/r8152.c
@@ -630,12 +630,10 @@ int set_registers(struct r8152 *tp, u16 value, u16 index, u16 size, void *data)
 	int ret;
 	void *tmp;
-	tmp = kmalloc(size, GFP_KERNEL);
+	tmp = kmemdup(data, size, GFP_KERNEL);
 	if (!tmp)
 		return -ENOMEM;
-	memcpy(tmp, data, size);
 	ret = usb_control_msg(tp->udev, usb_sndctrlpipe(tp->udev, 0),
 			       RTL8152_REQ_SET_REGS, RTL8152_REQT_WRITE,
 			       value, index, tmp, size, 500);
