qlogic: Deletion of unnecessary checks before two function calls
Author: Markus Elfring <elfring@users.sourceforge.net>
The functions kfree() and vfree() perform also input parameter validation.
Thus the test around their calls is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: David S. Miller
 drivers/net/ethernet/qlogic/qlcnic/qlcnic_main.c   | 24 ++++++++--------------
 .../net/ethernet/qlogic/qlcnic/qlcnic_minidump.c   |  3 +--
 2 files changed, 9 insertions(+), 18 deletions(-)
diff --git a/drivers/net/ethernet/qlogic/qlcnic/qlcnic_main.c b/drivers/net/ethernet/qlogic/qlcnic/qlcnic_main.c
index 2528c3f..a430a34a 100644
--- a/drivers/net/ethernet/qlogic/qlcnic/qlcnic_main.c
+++ b/drivers/net/ethernet/qlogic/qlcnic/qlcnic_main.c
@@ -294,9 +294,7 @@ int qlcnic_alloc_sds_rings(struct qlcnic_recv_context *recv_ctx, int count)
 void qlcnic_free_sds_rings(struct qlcnic_recv_context *recv_ctx)
-	if (recv_ctx->sds_rings != NULL)
-		kfree(recv_ctx->sds_rings);
+	kfree(recv_ctx->sds_rings);
 	recv_ctx->sds_rings = NULL;
@@ -1257,8 +1255,7 @@ qlcnic_check_options(struct qlcnic_adapter *adapter)
 	if (ahw->op_mode != QLCNIC_NON_PRIV_FUNC) {
 		if (fw_dump->tmpl_hdr == NULL ||
 				adapter->fw_version > prev_fw_version) {
-			if (fw_dump->tmpl_hdr)
-				vfree(fw_dump->tmpl_hdr);
+			vfree(fw_dump->tmpl_hdr);
 			if (!qlcnic_fw_cmd_get_minidump_temp(adapter))
 				dev_info(&pdev->dev,
 					"Supports FW dump capability\n");
@@ -2374,13 +2371,12 @@ void qlcnic_free_tx_rings(struct qlcnic_adapter *adapter)
 	for (ring = 0; ring < adapter->drv_tx_rings; ring++) {
 		tx_ring = &adapter->tx_ring[ring];
-		if (tx_ring && tx_ring->cmd_buf_arr != NULL) {
+		if (tx_ring) {
 			vfree(tx_ring->cmd_buf_arr);
 			tx_ring->cmd_buf_arr = NULL;
-	if (adapter->tx_ring != NULL)
-		kfree(adapter->tx_ring);
+	kfree(adapter->tx_ring);
 int qlcnic_alloc_tx_rings(struct qlcnic_adapter *adapter,
@@ -2758,13 +2754,9 @@ static void qlcnic_remove(struct pci_dev *pdev)
 	qlcnic_dcb_free(adapter->dcb);
 	qlcnic_detach(adapter);
-	if (adapter->npars != NULL)
-		kfree(adapter->npars);
-	if (adapter->eswitch != NULL)
-		kfree(adapter->eswitch);
+	kfree(adapter->npars);
+	kfree(adapter->eswitch);
 	if (qlcnic_82xx_check(adapter))
 		qlcnic_clr_all_drv_state(adapter, 0);
@@ -2932,13 +2924,13 @@ void qlcnic_alloc_lb_filters_mem(struct qlcnic_adapter *adapter)
 static void qlcnic_free_lb_filters_mem(struct qlcnic_adapter *adapter)
-	if (adapter->fhash.fmax && adapter->fhash.fhead)
+	if (adapter->fhash.fmax)
 		kfree(adapter->fhash.fhead);
 	adapter->fhash.fhead = NULL;
 	adapter->fhash.fmax = 0;
-	if (adapter->rx_fhash.fmax && adapter->rx_fhash.fhead)
+	if (adapter->rx_fhash.fmax)
 		kfree(adapter->rx_fhash.fhead);
 	adapter->rx_fhash.fmax = 0;
diff --git a/drivers/net/ethernet/qlogic/qlcnic/qlcnic_minidump.c b/drivers/net/ethernet/qlogic/qlcnic/qlcnic_minidump.c
index c9f57fb..332bb8a 100644
--- a/drivers/net/ethernet/qlogic/qlcnic/qlcnic_minidump.c
+++ b/drivers/net/ethernet/qlogic/qlcnic/qlcnic_minidump.c
@@ -1407,8 +1407,7 @@ void qlcnic_83xx_get_minidump_template(struct qlcnic_adapter *adapter)
 	current_version = qlcnic_83xx_get_fw_version(adapter);
 	if (fw_dump->tmpl_hdr == NULL || current_version > prev_version) {
 			dev_info(&pdev->dev, "Supports FW dump capability\n");
BtrLinux
Privacy Overview
