qlcnic: Remove casts of pointer to same type
Author: Joe Perches <joe@perches.com>
Casting a pointer to a pointer of the same type is pointless,
so remove these unnecessary casts.
Done via coccinelle script:
$ cat typecast_2.cocci
type T;
T *foo;
-	(T *)foo
+	foo
Signed-off-by: Joe Perches
Acked-by: Shahed Shaikh
Signed-off-by: David S. Miller
 drivers/net/ethernet/qlogic/qlcnic/qlcnic_83xx_init.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/ethernet/qlogic/qlcnic/qlcnic_83xx_init.c b/drivers/net/ethernet/qlogic/qlcnic/qlcnic_83xx_init.c
index ec399b7..2d91975 100644
--- a/drivers/net/ethernet/qlogic/qlcnic/qlcnic_83xx_init.c
+++ b/drivers/net/ethernet/qlogic/qlcnic/qlcnic_83xx_init.c
@@ -1388,7 +1388,7 @@ static int qlcnic_83xx_copy_fw_file(struct qlcnic_adapter *adapter)
 	addr = (u64)dest;
 	ret = qlcnic_83xx_ms_mem_write128(adapter, addr,
-					  (u32 *)p_cache, size / 16);
+					  p_cache, size / 16);
 	if (ret) {
 		dev_err(&adapter->pdev->dev, "MS memory write failed\n");
 		release_firmware(fw);
