qlcnic: constify qlcnic_mbx_ops structure
Author: Julia Lawall <julia.lawall@lip6.fr>
The only instance of a qlcnic_mbx_ops structure is never modified.  Thus
the declaration of the structure and all references to the structure type
can be made const.
In the definition of the qlcnic_mailbox structure, the ops field is no
longer lined up with the other fields.  This was left as is, to avoid a lot
of trivial changes on the other lines.
Done with the help of Coccinelle.
Signed-off-by: Julia Lawall
Acked-by: Sony Chacko
Signed-off-by: David S. Miller
 drivers/net/ethernet/qlogic/qlcnic/qlcnic.h         | 2 +-
 drivers/net/ethernet/qlogic/qlcnic/qlcnic_83xx_hw.c | 4 ++--
 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/net/ethernet/qlogic/qlcnic/qlcnic.h b/drivers/net/ethernet/qlogic/qlcnic/qlcnic.h
index d6696cf..46bbea8 100644
--- a/drivers/net/ethernet/qlogic/qlcnic/qlcnic.h
+++ b/drivers/net/ethernet/qlogic/qlcnic/qlcnic.h
@@ -1092,7 +1092,7 @@ struct qlcnic_filter_hash {
 struct qlcnic_mailbox {
 	struct workqueue_struct	*work_q;
 	struct qlcnic_adapter	*adapter;
-	struct qlcnic_mbx_ops	*ops;
+	const struct qlcnic_mbx_ops *ops;
 	struct work_struct	work;
 	struct completion	completion;
 	struct list_head	cmd_q;
diff --git a/drivers/net/ethernet/qlogic/qlcnic/qlcnic_83xx_hw.c b/drivers/net/ethernet/qlogic/qlcnic/qlcnic_83xx_hw.c
index 9f0bdd9..37a731b 100644
--- a/drivers/net/ethernet/qlogic/qlcnic/qlcnic_83xx_hw.c
+++ b/drivers/net/ethernet/qlogic/qlcnic/qlcnic_83xx_hw.c
@@ -4048,7 +4048,7 @@ static void qlcnic_83xx_mailbox_worker(struct work_struct *work)
 	struct qlcnic_mailbox *mbx = container_of(work, struct qlcnic_mailbox,
 						  work);
 	struct qlcnic_adapter *adapter = mbx->adapter;
-	struct qlcnic_mbx_ops *mbx_ops = mbx->ops;
+	const struct qlcnic_mbx_ops *mbx_ops = mbx->ops;
 	struct device *dev = &adapter->pdev->dev;
 	atomic_t *rsp_status = &mbx->rsp_status;
 	struct list_head *head = &mbx->cmd_q;
@@ -4098,7 +4098,7 @@ static void qlcnic_83xx_mailbox_worker(struct work_struct *work)
-static struct qlcnic_mbx_ops qlcnic_83xx_mbx_ops = {
+static const struct qlcnic_mbx_ops qlcnic_83xx_mbx_ops = {
 	.enqueue_cmd    = qlcnic_83xx_enqueue_mbx_cmd,
 	.dequeue_cmd    = qlcnic_83xx_dequeue_mbx_cmd,
 	.decode_resp    = qlcnic_83xx_decode_mbx_rsp,
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
