qla4xxx: Use kmemdup instead of kmalloc + memcpy
Author: Benoit Taine <benoit.taine@lip6.fr>
This issue was reported by coccicheck using the semantic patch
at scripts/coccinelle/api/memdup.cocci
Signed-off-by: Benoit Taine
Acked-by: Vikas Chaudhary
Signed-off-by: Christoph Hellwig
 drivers/scsi/qla4xxx/ql4_os.c | 7 +++----
 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/drivers/scsi/qla4xxx/ql4_os.c b/drivers/scsi/qla4xxx/ql4_os.c
index 9eef7d4..3202063 100644
--- a/drivers/scsi/qla4xxx/ql4_os.c
+++ b/drivers/scsi/qla4xxx/ql4_os.c
@@ -3565,14 +3565,13 @@ static int qla4xxx_copy_from_fwddb_param(struct iscsi_bus_flash_session *sess,
 	if (test_bit(OPT_IPV6_DEVICE, &options)) {
 		conn->ipv6_traffic_class = fw_ddb_entry->ipv4_tos;
-		conn->link_local_ipv6_addr = kzalloc(IPv6_ADDR_LEN, GFP_KERNEL);
+		conn->link_local_ipv6_addr = kmemdup(
+					fw_ddb_entry->link_local_ipv6_addr,
+					IPv6_ADDR_LEN, GFP_KERNEL);
 		if (!conn->link_local_ipv6_addr) {
 			rc = -ENOMEM;
 			goto exit_copy;
-		memcpy(conn->link_local_ipv6_addr,
-		       fw_ddb_entry->link_local_ipv6_addr, IPv6_ADDR_LEN);
 	} else {
 		conn->ipv4_tos = fw_ddb_entry->ipv4_tos;
BtrLinux
Privacy Overview
