pxa3xx-cpufreq.c: Avoid using ARRAY_AND_SIZE(e) as a function argument
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Replace ARRAY_AND_SIZE(e) in function argument position to avoid
hiding the arity of the called function.
The semantic match that makes this change is as follows:
(http://coccinelle.lip6.fr/)
expression e,f;
f(...,
- ARRAY_AND_SIZE(e)
+ e,ARRAY_SIZE(e)
Signed-off-by: Julia Lawall
Acked-by: Viresh Kumar
Signed-off-by: Rafael J. Wysocki
drivers/cpufreq/pxa3xx-cpufreq.c | 6 ++++--
1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/drivers/cpufreq/pxa3xx-cpufreq.c b/drivers/cpufreq/pxa3xx-cpufreq.c
index 9c92ef0..d26306f 100644
--- a/drivers/cpufreq/pxa3xx-cpufreq.c
+++ b/drivers/cpufreq/pxa3xx-cpufreq.c
@@ -213,10 +213,12 @@ static int pxa3xx_cpufreq_init(struct cpufreq_policy *policy)
policy->cur = policy->min = policy->max;
if (cpu_is_pxa300() || cpu_is_pxa310())
- ret = setup_freqs_table(policy, ARRAY_AND_SIZE(pxa300_freqs));
+ ret = setup_freqs_table(policy, pxa300_freqs,
+ ARRAY_SIZE(pxa300_freqs));
if (cpu_is_pxa320())
- ret = setup_freqs_table(policy, ARRAY_AND_SIZE(pxa320_freqs));
+ ret = setup_freqs_table(policy, pxa320_freqs,
+ ARRAY_SIZE(pxa320_freqs));
if (ret) {
pr_err("failed to setup frequency table\n"); |
if (ret) {
