pwm: simplify use of devm_ioremap_resource
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Remove unneeded error handling on the result of a call to
platform_get_resource when the value is passed to devm_ioremap_resource.
Move the call to platform_get_resource adjacent to the call to
devm_ioremap_resource to make the connection between them more clear.
A simplified version of the semantic patch that makes this change is as
follows: (http://coccinelle.lip6.fr/)
expression pdev,res,n,e,e1;
expression ret != 0;
identifier l;
- res = platform_get_resource(pdev, IORESOURCE_MEM, n);
  ... when != res
- if (res == NULL) { ... \(goto l;\|return ret;\) }
  ... when != res
+ res = platform_get_resource(pdev, IORESOURCE_MEM, n);
  e = devm_ioremap_resource(e1, res);
Signed-off-by: Julia Lawall
Acked-by: Viresh Kumar
Signed-off-by: Thierry Reding
 drivers/pwm/pwm-lpc32xx.c     | 3 ---
 drivers/pwm/pwm-renesas-tpu.c | 5 -----
 drivers/pwm/pwm-spear.c       | 7 +------
 3 files changed, 1 insertion(+), 14 deletions(-)
diff --git a/drivers/pwm/pwm-lpc32xx.c b/drivers/pwm/pwm-lpc32xx.c
index efb6c7b..efac99e0 100644
--- a/drivers/pwm/pwm-lpc32xx.c
+++ b/drivers/pwm/pwm-lpc32xx.c
@@ -124,9 +124,6 @@ static int lpc32xx_pwm_probe(struct platform_device *pdev)
 		return -ENOMEM;
 	res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
-	if (!res)
-		return -EINVAL;
 	lpc32xx->base = devm_ioremap_resource(&pdev->dev, res);
 	if (IS_ERR(lpc32xx->base))
 		return PTR_ERR(lpc32xx->base);
diff --git a/drivers/pwm/pwm-renesas-tpu.c b/drivers/pwm/pwm-renesas-tpu.c
index 3eeffff..aff6ba9 100644
--- a/drivers/pwm/pwm-renesas-tpu.c
+++ b/drivers/pwm/pwm-renesas-tpu.c
@@ -418,11 +418,6 @@ static int tpu_probe(struct platform_device *pdev)
 	/* Map memory, get clock and pin control. */
-	if (!res) {
-		dev_err(&pdev->dev, "failed to get I/O memory\n");
-		return -ENXIO;
 	tpu->base = devm_ioremap_resource(&pdev->dev, res);
 	if (IS_ERR(tpu->base))
 		return PTR_ERR(tpu->base);
diff --git a/drivers/pwm/pwm-spear.c b/drivers/pwm/pwm-spear.c
index a54d214..8ad26b8 100644
--- a/drivers/pwm/pwm-spear.c
+++ b/drivers/pwm/pwm-spear.c
@@ -178,18 +178,13 @@ static int spear_pwm_probe(struct platform_device *pdev)
 	int ret;
 	u32 val;
-	r = platform_get_resource(pdev, IORESOURCE_MEM, 0);
-	if (!r) {
-		dev_err(&pdev->dev, "no memory resources defined\n");
-		return -ENODEV;
 	pc = devm_kzalloc(&pdev->dev, sizeof(*pc), GFP_KERNEL);
 	if (!pc) {
 		dev_err(&pdev->dev, "failed to allocate memory\n");
 		return -ENOMEM;
+	r = platform_get_resource(pdev, IORESOURCE_MEM, 0);
 	pc->mmio_base = devm_ioremap_resource(&pdev->dev, r);
 	if (IS_ERR(pc->mmio_base))
 		return PTR_ERR(pc->mmio_base);
BtrLinux
Privacy Overview
